Front Sunroof Drains - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2008, 09:57 AM   #1 (permalink)
View dsin's Photo Gallery
I have a 1997 Camry with what I have now been able to determine is an aftermarket sunroof. I have been able to determine that the ends of the drainage tubes were never installed to exit the vehicle and thus water simply drained into the car and then found its way out through the body seams after soaking everything in the pathway. I am now correcting it and think I know where to make the back ones exit through the trunk. I found the ends of the front drain tubes in the A columns behind a relay box behind the front kick panel. I was able to push the end of the tubes down a hole in this space. I can then see the end of the tube by peeling back the plastic fender well and taking out a grommet on the front of the door jam but there is no exit here out of the body short of drilling a hole up from the bottom through 2 areas of sheet metal that will be hard to seal or bending the hose at a 90 to bring it out the grommet hole (something I really don't want to do because of the constriction it causes). Can anyone help me by telling me where the factory installed front drains specifically exit the body so I can get them in the right place?
dsin is offline   Reply With Quote
