Originally Posted by hdd
Did you think about drilling holes in the factory brackets to push the unit back? I am thinking of doing it for 01 Camry. I just installed it last weekend.
Do you have cooling fan noise issue? Mine seems to be loud and not sure if its normal,
Were you able to hide the BT module inside the dash?
Thanks
I thought about drilling the brackets also but then there would be gap on each side of the monitor plus since I sit far back in the seat having the radio a little closer to me is a good thing.
Yea the fan can be heard when the car is off and the radio on, I don't here it while driving. I put the BT module under the drivers seat it was easy to run the cable with the seat out and it went under the console/carpet without pulling the center console out.
