when I was modifying my steering wheel controls for my '05, i had pulled the cruise control/horn connector. neither worked while the connector was disconnected... probably very similar to your situation. i did not have to pull the steering wheel to access the connector, just the airbag... it may be the same for your '95. clean the contacts and make sure nothing is shorting out.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
