clicking sound from the rear when braking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2008, 08:00 AM   #1 (permalink)
View beingblueeyes's Photo Gallery
hey all i have a 95 Camry 5sfe 5 speed, front disc and rear drums. when i brake over 50% it sounds like there is a clicking coming from my rear drums kinda like a horse is fallowing me around, I’ve replaced the shoes spring kit and drums and still the sound is there...anyone come across thing before?
Blue
beingblueeyes is offline   Reply With Quote
Old 06-14-2008, 03:17 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You killed my first suspicion when you said that you replaced all of the brake paraphenalia. I don't suspect a mechanical problem in the suspension so much since it is making a repeating noise while you are steadily braking. (One thud and it might be a loose joint or failing rubber.) That leaves the tires as the next easiest thing to check. Have you switched them front to rear yet? Try it and see if the noise moves with the tires.
Kep
Old 06-14-2008, 03:24 PM   #3 (permalink)
View toyomoho's Photo Gallery
Might be a warped drum causing the brake parts to move around.
Old 06-14-2008, 08:47 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
could the clicking sound be a metal rubbing sound in disguise? my rear drums are rusting pretty badly where they are starting to rub on the dust shield every so often. it almost sounds like a ticking sound with the rotation on the wheel.
Old 06-14-2008, 09:56 PM   #5 (permalink)
I’ve tried switching the drums side to side and it didn’t help, (trying to find out witch side its coming from and it didn’t work, but I haven’t tried moving the tires around yet, ill try that tomorrow. could it be a rear wheel bearing that’s worn out and causing the drums to move around on the shoes?
Old 06-14-2008, 10:37 PM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
I had an issue a while back where the rear brakes would click, frequency dependent on speed, when I applied the brakes. I had a shop fix and they told me they just resurfaced the drums.
2007 Camry 2.4L 5M
