Running RICH LEAN MORE AIR LESS AIR ~ oh so confusing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2008, 10:48 PM   #1 (permalink)
w00! I drive a Camry
View CamBOT's Photo Gallery
Hey guys I am so confused about fuel mixtures and AF ratios.
Running Rich = not enough air, un brunt fuel
Lean= too much air
My problem is that when i start my car i notice the smell of gas at the exhaust. I verified that there are no fuel leaks. Doesnt this usually indicate a rich mixture?
I recently added a cone filter setup. Then did the AFM mod mentioned here.
http://www.toyotanation.com/forum/t82158.html ( i leaned it about 5-8 clicks)
But i'm confused according that post we lean the mixture my rotating the cog clockwise. This has a tightening effect on the AFM valve. That means less air will enter.
How is this leaning out the car....oh so very confused.
Help me out guys.
( I'll check out my plugs tomorrow to check if they are the culprit for the gas smell)
Thanks
CamBOT
CamBOT is offline   Reply With Quote
Old 06-15-2008, 10:26 AM   #2 (permalink)
Thoughts?
CamBOT
Old 06-15-2008, 11:16 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
There are a lot more AFMs on the GEN 2s. You might put a post on that forum. They might have more input.
Meanwhile, (AFTER marking the original tooth on the AFM gear, you want to be able to revert to factory spec) why not adjust the AFM the other way and see if it corrects the problem.
Kep
Old 06-15-2008, 11:18 AM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
uh ... less air = rich ... if you are closing the valve that lets less air in, youre not leaning it out
ive never seen a 3VZ, so idk how the AFM is setup ... but make sure its doing what you actually think its doing
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-15-2008, 12:36 PM   #5 (permalink)
I marked the original position so I can revert it back.
I'm just curious if someone else has the AFM mod done on the 3Vz
CamBOT
Old 06-15-2008, 05:19 PM   #6 (permalink)
engineer in training
Gameroom cash: $145055
The AFM is not restricting the flow of air into the engine at all. By tightening the spring it is harder to open the afm and so it will MEASURE less air coming in, the ecu sees less air coming in and doesn't know to add more fuel.
