Gen 4 v6 Noisy Lifters? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2008, 08:42 PM   #1 (permalink)
'97 Camry V6 XLE
View thegmann's Photo Gallery
4th Generation Gen 4 v6 Noisy Lifters?
Can anyone tell me what the repeated clicking noise is? I'm thinking its the valves/ lifters.
If I'm right what can I do about?
I'm thinking about trying the Seafoam stuff everyone keeps talking about.
thegmann is offline   Reply With Quote
Old 06-16-2008, 10:48 AM   #2 (permalink)
View nikita's Photo Gallery
Toyota lifters are not hydraulic so no, they are not sticking and no additive is going to make any difference. A little noise is perfectly normal, a lot and they may need adjusting. There should be an underhood sticker with the clearance spec.
nikita is offline   Reply With Quote
Old 06-16-2008, 12:46 PM   #3 (permalink)
'97 Camry V6 XLE
Thanks for your reply.
The clicking is a lot louder than it seems in the video so I guess I will go see about having them adjusted.
Old 06-16-2008, 02:33 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
your sure its not an exhaust leak? when its at the manifold(usually the rear one) it sounds alot like lifters clacking.
any performance problems...that will usually acompany ANY problem with the valve train.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-16-2008, 07:35 PM   #5 (permalink)
'97 Camry V6 XLE
It seems to run fine. What kind of problems would the exhaust leak cause?
Old 06-16-2008, 07:55 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
none unless its bad, then it may cause one of the O2 sensors to trip. id check teh exhaust manifold gaskets and see if they are leaking. put water in a spray bottle and spray them all around...best when the engine is on a cold start.
R.I.P.
Car Domain:
Old 06-16-2008, 08:04 PM   #7 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
thats what my motor sounds like, I think your talking about injector tick.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 06-16-2008, 10:04 PM   #8 (permalink)
'97 Camry V6 XLE
What ever the clicking is it is in sink with the motor. When I rev it the speed of the clicks goes up. So injectors would make sense.
So thats the way its supposed to sound?
Old 06-16-2008, 10:47 PM   #9 (permalink)
shajbot's Avatar
View shajbot's Photo Gallery
Mine seems to be leaking (water vapor in different areas), I have the same clicking noises, what do I do now??
shajbot is offline   Reply With Quote
Old 06-16-2008, 11:57 PM   #10 (permalink)
samarai912's Avatar
yeah thats what just what the injectors sound like. you could place one finger on the injector and rev your engine and actaully feel the injector pulse if you wanna make sure its that.
try some seafoam through a tank of gas...actaully through the whole system.
