Weird sound in back continues, HELP PLEASE ASAP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2008, 09:40 PM   #1 (permalink)
View 95toyotacamry's Photo Gallery
As i described in a previous threat about the clunck clunck sound in the rear of my 95 camry. I went to the mechanic and my sway bar bushings were good, the strut mounts according to them were good. But the sound is still there. And no is not tools rolling around i took all my tools out of my car. Is there a way i can test to see is my struts are in good working condition?? This sound is like a big headache i dont know how to get rid of, i need help ASAP, anything you can think of please let me know! Thanx:conf used:
95toyotacamry is offline   Reply With Quote
Old 06-17-2008, 12:35 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
When does it clunk, does it change as the car speeds up or when you are braking or coasting?
Kep
Old 06-17-2008, 12:44 PM   #3 (permalink)
Kep
Is just when i hit a hole. Is like clunk clunk and im lik wut the hell!!LOL That sound is the worst. Any idea of what it might be?
Old 06-17-2008, 12:45 PM   #4 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
It's probably the RSB hitting the gas tank or some bolts loose on a component connect to the strut
RichieRichJP is offline   Reply With Quote
Old 06-17-2008, 12:49 PM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
make sure your rims are tighten. i had the same problem also wasted money on nothing really serious and that was the problem. Make sure they are tighten ( the nuts ) and check teh studs, the threads maybe be going losening the nuts
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 06-17-2008, 12:50 PM   #6 (permalink)
What is an RSB??
95' Camry Sedan 125k-The devil can get in a camry, and it will still work!
Old 06-17-2008, 12:51 PM   #7 (permalink)
View nhan070's Photo Gallery
Thats clunk sound might be sign of your end-links giving up on you. What you described sounds like what I experienced when I had one of the end-links nut loose while attempting to change the rsb (stripped the hex nut on the end-links so nut was stuck). I had to endure that for 2 whole weeks until the parts came. I hope that's your problem...if it is, it's an easy fix.
'95 I4 Camry sedan (Japan), Silver Annv., nearing 200K
nhan070 is offline   Reply With Quote
Old 06-17-2008, 01:06 PM   #8 (permalink)
What is an RSB??
Rear Sway Bar
Old 06-17-2008, 01:09 PM   #9 (permalink)
Just curious is there a way that you can check if the struts themselves are bad. Like without having to unmount anything.
Old 06-17-2008, 01:11 PM   #10 (permalink)
Yeah, push down on the back of the car on either side.
If your suspension is good, it should spring back up to normal
Old 06-17-2008, 01:14 PM   #11 (permalink)
How many times should it bounce up?
Old 06-17-2008, 03:02 PM   #12 (permalink)
It should be stiff. If it "bounces", your spring is in work but the strut isn't "dampening."
If it's bouncy, then you know you have a problem
Old 06-17-2008, 09:11 PM   #13 (permalink)
I did the pushing down test. IT only came back up once. Then i got my bro and we pushed down many times and it came up it was not bouncy. So this means the struts are good rite.
Old 06-24-2008, 08:06 PM   #14 (permalink)
View joede's Photo Gallery
Sway bar bushing check
How did that mechanic check your sway bar bushings? Unless he dis assembled each bushing from the sawy bar mounts and loofed at each bushing's inside diameter, his inspection means little.
I have moved, shook and pried on those bushings in their assembled state with the sawy bar and no movement was seen. However when I disassembled the same bushings and inspected the inside diameter of each, one of them was clearly worn out of round and it's inside diameter was oblong. I then replaced the set aand no more "clunking".
Please note that if your rear shocks/struts are worn ie they do not stop the car from bouncing, these worn rear struts can also cause those sway bar bushings to wear out prematurely.
To sum up, in my opinion it sounds like your rear struts are shot and it is probably a good bet that your sway bar bushings are worn.
I am curious, how did yyour mechanic tell that your shock mounts are OK without removing the rear strut assembly from the car? I personally have not been able to diagnose a worm Camry strut mount unless I removed the strut from the car and inspected it on the bench.
Hope this helps.
joede is offline   Reply With Quote
Old 07-11-2008, 12:24 PM   #15 (permalink)
View toyotamann's Photo Gallery
Did you figure it out ? my car is doing the same thing !
toyotamann is offline   Reply With Quote
