problem with a headlight - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2008, 10:01 PM   #1 (permalink)
View Camry LE 94's Photo Gallery
3rd Generation problem with a headlight
Hi everyone, I have a 96 Camry LE and it just recently started that one of my headlights doesnt turn on when i start my car. I bought brand new Nokya Arctic White bulbs a couple months ago and replaced the factory ones, but i never had a problem until now. When I open my hood and move the bulb slightly, it'll turn back on. But when I turn them off and back on, the same bulb wont turn on. I'm sick of gettin pulled over all the time now because sometimes ill forget to check the damn thing. Anybody know or may have an idea of what the problem is? Thanks a lot.
Camry LE 94 is offline   Reply With Quote
Old 06-17-2008, 12:39 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If you can wiggle it to get it to work then it sounds like a loose wire or connection or maybe a bad bulb. Swap the bulbs from left to right. If the problem moves, then it is the bulb. If not, then you have a wiring problem.
Kep
