Chrome Piece Around window - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2008, 01:42 AM   #1 (permalink)
Blckdout97camry
View jakemm52's Photo Gallery
4th Generation Chrome Piece Around window
i have a black xle and it has a chrome strip around the windows, i was wondering if anyone knows if it can come off.
Also does anyone have any pictures on how to take the bumber off
jakemm52 is offline   Reply With Quote
Old 06-18-2008, 02:32 AM   #2 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Don't really like a lot of chrome myself. From what I've seen of mine, it doesn't seem like you can take it off, but you can buy special tape that goes over it. Check your local auto parts store. It's usually in with all the trim stuff.
cykaaro is offline   Reply With Quote
Old 06-18-2008, 02:51 AM   #3 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
use trimbrite blackout tape
TheKevin is offline   Reply With Quote
Old 06-18-2008, 11:49 AM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Which bumper are you trying to take off, the front or rear? They're both pretty simple on a gen 4.
Chris Crash is online now   Reply With Quote
Old 06-18-2008, 12:36 PM   #5 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I need to know how to take the bottom rear ones out, they're all bent up.
I made a DIY on this before (front passenger and drivers sides), search it!
RichieRichJP is offline   Reply With Quote
Old 06-19-2008, 12:30 PM   #6 (permalink)
Blckdout97camry
im trying to take off the front
Old 06-19-2008, 12:37 PM   #7 (permalink)
Open the hood and look at the top of the bumper...right in front of the radiator. There's 3-4 plastic screws. Undo the screws as far as you can, then pop them out.
Underneath the bumper, in the middle look straight up. Then look a little to the left and right. Those plastic screws show up again. Undo those.
Undo all the air dams and plastic guards from the bumper under the car, don't forget the plastic around the wheels, too!
This one is the hard part. Reach under the bumper until your hand is near the side of the headlight/cornering light. Try to find a bolt that is holding it on. There's one on each side, and it's a 10mm bolt. Use a wrench, because there's no way you can fit a socket up there. If you're lucky, you can save yourself the trouble by using a ratcheting wrench.
Once you get those off, there are two clips holding the bumper. They're right below the headlights if you look from the front. Try pulling the bumper out very gently to see these. Then take a screwdriver to release them.
Good luck, hope that helped.
