How to Disconnect the Alarm? (92) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2008, 08:28 PM   #1 (permalink)
View Rob_0126's Photo Gallery
I have a 92 camry v6 XLE with a factory alarm. The switch is down by the kick panel next to the emergency brake.
How do I remove it from the car? It is acting up and I dont use it anyways. Anyone have a clue how to do this? Ive searched the forums to no avail.
thanks
Robert
Rob_0126 is offline   Reply With Quote
Old 06-18-2008, 08:40 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Do you know where the alarm computer module is? It's probably close to that switch. Try removing the kickpanel and look around. Follow the wire from the switch, see where it takes you. Then, on that module there should be a big clip on one side. If you no longer want the alarm, just remove the clip and all the wires connected to it.
Chris Crash is online now   Reply With Quote
Old 06-18-2008, 10:29 PM   #3 (permalink)
Thanks, Ill check that out Chris.
Old 06-19-2008, 01:17 PM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
It's wedged up under the lower panels under the steering column. I know...I disconnected mine when I pulled my dashboard out. They wedge it in there good and strap wires everywhere....so have fun. I just have mine switched to off (kick panel switch position towards front of car) until I get my remotes working again.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-19-2008, 08:21 PM   #5 (permalink)
I have it switched to off, but it still beeps sometimes. I get a 4 beep rarely, ideas?
I just want to stop it period, I never use it.
