Alarm not sounding. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2008, 02:07 AM   #1 (permalink)
View jase_21's Photo Gallery
Alarm not sounding.
Hey guys
I have a 93 camry. My problem is that the alarm does not sound. It looks like it goes off (ie lights flash and it immobilizes) but there is just no sound or 'alarm'. Does anyone know what this could be? It also doesn't 'beep' when you turn the alarm on or off.
I'm guessing this means it might be disconnected from the horn??
Also does anyone no where the factory alarm would be located?
thanks in advance!
jase
jase_21 is offline   Reply With Quote
Old 06-19-2008, 12:31 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
The horn is probably located in the engine bay, near the wheel wells. Follow the wire from it to see if it's plugged in. If it is plugged in, has the alarm speaker been facing up towards the hood of the car? If so, water got in it and it no longer will work.
Chris Crash is online now   Reply With Quote
Old 06-19-2008, 01:14 PM   #3 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Did you buy the car used? I have a simple keyless entry + engine immobilizer system on the gen 3.5 and it behaves exactly the way you mentioned. It has no siren and it's not hooked up to the horn either. Your alarm may not be malfunctioning, rather..it's more of a keyless entry system with an added immobilizer.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 06-20-2008, 09:59 PM   #4 (permalink)
yes i did buy it used. that might be the problem :P but it sure looks as if an alarm is meant to go off as the lights flash etc.
Old 06-20-2008, 10:16 PM   #5 (permalink)
Same here. It's got a 'Valet' switch and a standard blinking LED light too. There just isn't a siren or a shock sensor
moving forward
