Anyone remove the differential cover (fill bolt side) before? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2008, 09:58 AM   #1 (permalink)
View lagvoid's Photo Gallery
After lots of cursing at myself for stripping/rounding the diff fill bolt, I'm hoping that I can remove the cover to try and get it out. I think I'll have enough room to get to the 10/12mm bolts that hold it in place, but I'm not too sure about whats up top. Also, is there a gasket or just RTV silicone to seal it back up?
I'd appreciate if anyone could provide any help or tips before I get myself into more trouble.
Thanks
lagvoid is offline   Reply With Quote
Old 06-19-2008, 12:01 PM   #2 (permalink)
View toyomoho's Photo Gallery
Is this the side plate. It is just an excess plate, nothing else. Manual states it has a gasket. 18 ft-lbs on the bolts. Toyota states to install the bolts with a tread sealant. Three Bond 1324 or equivalent, a Google search should turn up equivalent products.
Old 06-19-2008, 12:14 PM   #3 (permalink)
It's probably the plate you're talking about. The side with the fill plug/cooling fins.
When I reached up towards the top, I felt that metal cylinder piece and wasn't sure what that was. I also could not see or feel if there were bolts at the top side to remove.
