It could be. You could probably verify it with a vacuum gauge.
Do you notice the problem more when the engine is hot or cold? Does it matter?
Before I spent a lot of money on parts I'd sure want to make sure that your emissions system is clean. Throttle body, EGR system, PCV, and (what the heck) IAC. Then do the Sea Foam routine (1/3 can in oil, 1/3 can in gas and 1/3 can sucked up into the brake booster vacuum tube). Afterwards, if it is still happening, there are some sensors that you could check.
Kep
