Don't go that way.....go for te relocation or put the wires of both the wires to getter!!!!!!!! That is the most easy job and also safe way.
1 year ago i put both te wires on 1 sensor
A couple of months ago the second knocksensor was killed then i did the relocation. The sensor is still detecting the knocks, so it is safe todo.
What you need for the relocation is:
-2 knock sensors
-1 Knock sensor harness
-2 bolts that fit on the knocksensor
-2 metal corner brackets (must be metal because the knocksenor must be grounded)
-1 hour to install
1. disconnect the battery.
2. disconnect, on the right side, the knocksenor harness...(compare the connector with your new harness to find it)
3. connect the new wire harness
4. mount the 2 senors on the brackets
5. loosen 1 bolt on the head and mount the bracket with that bolt on the head
http://i232.photobucket.com/albums/e...DSC08009-1.jpg
http://i232.photobucket.com/albums/e...k/DSC08010.jpg
6. Repeat 4. for the second sensor.
7. Connect the wire harness with the sensors.
8 connect the battery
9. And drive!
If the sensor gives a error check if the sensors are grounded.
