AC + Turning = Dead car, please help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2008, 05:23 PM   #1 (permalink)
View SmartedPanda's Photo Gallery
3rd Generation AC + Turning = Dead car, please help.
Hi, it's freakin hot in california. This situation has happened to my camry and I don't know the reason, whenever I run the car for longer than 30 mins, than turn on the AC for over 10 mins, I can't turn.
You heard me, AC + Turning would do three things, make my car literally die, as in it struggles so hard that it literally about to shut off, or it jerks real hard forwards and dies. Or the best situation I pray for just slow down the turn to the point it's still in control/working.
It doesn't always happen it random, usually when I'm in a stopped position and move on/turn, and only has happened once when I was driving.
This situation has almost KILLED me three times, and I have a minor BUMP from a car.
Does anyone know what's wrong?
I can't afford a good, cheap or "friend" mechanic due to college student, and just the job market f-king me over.
I really need my car fixed and done by the end of the month or else bad things happen..
Thank you for reading, and please any input is helpful.
INFO: 1992 Camry, Inline 4, new timing belt, checked all the oils, and has happened a few times. Sometimes the car doesn't even start due to the battery, but this one is about 1 month old and hasn't happened so far.
1992 Camry. 4dr Sedan. 3rd Gen.
2.2L 5S-FE I4, with ~167K Miles.
Trying to get my baby restored...
So Far: Dual XHD-6425
SmartedPanda is offline   Reply With Quote
Old 06-19-2008, 06:00 PM   #2 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Ouch, I can't help you out other than to hope it works out. If your A/C is off, does the car work okay? If so - at least you've got wheels. A friend of mine has a Legend and her A/C broke just recently. It can easily get up into the 90s here during the summer. She can't afford to fix it so she's just driving without it.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 06-19-2008, 06:06 PM   #3 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426253
View EEngineer's Photo Gallery
power steering belt runs AC compressor too no?
if that's the case...check that out
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 06-19-2008, 06:07 PM   #4 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
here's a speculation, but i'm not quite sure where i'm going with it:
ac/accesory belt is right next to the power steering belt , at least on the v6 it is, so maybe on the i4 it's similar. maybe somebody here can keep going with this idea.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-19-2008, 06:31 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
How hot is your power steering fluid (ATF) getting? Hot enough that if it were contaminated it might not work right? Is your ATF steering fluid topped off?
Kep
Old 06-19-2008, 06:39 PM   #6 (permalink)
View toyomoho's Photo Gallery
A few thoughts.
I4 has separate belt for PS not connected with A/C.
Turning on the A/C should cause the engine to idle up and down with compressor operation due to increase HP needs. Does the engine idle up when the AC is turned on and compressor working?
Turning the steering wheel should also cause the engine to increase idle speed to compensate for added PS pump loads.
Perhaps one, the other or both idle up systems are not working causing extra load on the engine, and with this a very low engine idle. Low idle = low PS pump RPM and lower power steering assist.
The car should be able to steer OK without the PS working, it is just a lot harder.
The steering wheel is not locking up, this has happened due to PS system problems but tends to be only for a second or to at very low speeds.
Old 06-19-2008, 07:29 PM   #7 (permalink)
To Toyo: Thanks, It does idle up slightly not noticeable for me, but if my dad (original owner) is standing within 10 feet he can tell the ac is on.
I checked all fluids, I'll recheck after a long drive and see if anything is leaking, or changed.
Also, the wheel does NOT lock up, but the engine literally just can't accelerate at all, it just struggles so much it dies. I just pushed the pedal to the floor once and it worked again but obviously that's not such a good idea since I'm in the city and its' always packed.
Hrm....I guess I gotta save up for a check up or something. Thanks guys, if anyone else has ANY idea please tell me. And dumb it down, because I'm really car-stupid.
Also, the car also gives off a really bad smell after 3.5RPMs, could that be related to the A/C + Turn issue?
Old 06-19-2008, 07:42 PM   #8 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
the bad smell is probably your catalytic converter
so....does the car do any of this when the a/c isn't on though?
HaHa
Old 06-19-2008, 08:09 PM   #9 (permalink)
Nope my car is fine without AC, and the smell comes from the engine bay, and smells anytime. I'll make a different thread if I can't find the smell so let's ignore that part haha.
My car is almost perfect with the AC off but it's freakin 92 F+ in california and it's not even summer yet so I just want to be able to drive, with the AC on and turn at the same time. Thank you.
Old 06-20-2008, 02:38 PM   #10 (permalink)
Desperate bump, and last bump I swear.
