Is it common for the 5S-FE motor to leak via the rear main seal or crank seal? I have a slight leak at the front and rear of the engine and am trying to pin point if its the sump or rear main.
Ive only just noticed it as the oil is dripping onto the exhaust so I can smell it every now and then.
1) check distrubutor O-Ring by touching (your hand) underneath the distrubutor when the engine is cold to see if leaks... Toyota cars are know to know distrubutor O-Ring get harder and leaks occur.. the distrubutor leaks,....you know when you're driving...the leak hit exhaust pipe..the smell burn occur....the best way to know...jack the car up and make sure everything SAFE before you get under your car to inspect (look up the distrubutor to see if leaks occur)... you need light when u go underneath, so you can see...
2) the front leaks possible the head gasket (where spark plugs go in the hold) ...
If oil is dripping onto the exhaust pipe, it could very well be the oil filter pedestal o-ring that is leaking. That's where it's leaking on my XLE in my sig. From the dealer, the o-ring is less than $10.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
Thanks
i found the same concern for my gen 3.5 seems to be leaking from where the inspection cover from the flex plate. i got to take it off and see if it start leaking from there
as well as my engine oil pan gasket seems to be wet a little bit too. i may need to re-seal that soon
Its not my distributor oring as its nice and clean up the top of the motor.
I tightened the sump bolts slightly (the ones I could access) and degreased the engine so I'll monitor it for the next few weeks and see what happens. Hopefully its just the sump gasket.
for the rear it is most probably (rear) main oil seal like you said....I changed mine month ago (I have 320000KM's on my Camry....don't know how much miles is that)....
Mine started dripping, and was dripping slowly on exhaust pipe, which created like a burnt smell...that how I noticed it...
Now to replace it is a pain....Hood out, engine out, automatic gearbox on the side....that is the proper way, cause you can then also replace all the seals on gearbox and everywhere since everything is out...
Once done, you are peaceful for quite a few thousands of kilometers (miles)
1994 Toyota Camry 220 SEI Automatic RHD (yes, stupid right hand drive since I moved to SA )...
[quote=1996camry;2381266]Two possible leaks can be...
OMFG! I made three posts, with no answers, and now I know wtf is wrong, I wanna have your babies.
1992 Camry. 4dr Sedan. 3rd Gen.
2.2L 5S-FE I4, with ~167K Miles.
Trying to get my baby restored...
So Far: Dual XHD-6425
If the rear main is leaking, would it cause oil to go onto the clutch plate and cause clutch sudder as that is what mine has been doing since I bought it?
Also, for the front, Ive done a search and the leaks can be from:
- oil pump o ring, gear
- front crank seal
- cam seal
Any others?
Looking at the front of my engine, the front has oil on the sides so its hard to tell if its coming from the oil pump or cam / crank seals. Would it be obvious once the timing cover / belts are removed?
Well just did a clean of the bottom end and then took it for a half hour drive. Jacked it up and there is oil around the front where the sump mates onto the block and also between the transmission and rear of the engine.
Here are some pictures
BEFORE CLEANING
The front of the engine is pretty oily, and its all over the front, so for this leak, Im guessing its a combination of the oil pump seal, crank and camshaft seal.
AFTER CLEANING
After cleaning the bottom end and driving it for about half an hour, the area between the transmission and rear of the engine has oil coming down. Possibly could be the sump gasket seal in this area, although Im guessing its the rear main seal. The front area has slight oil around where the sump mates onto the engine block. Oil pump housing has slight weeping where it joins to the block (is that job the o-ring does?)
1.
the front side does look like the oil pump area. i did a quick how-to and included photos (link below) if you are curious to see what the o-ring looks like. you have to pop-off the timing belt cover to see for sure. might as replace teh other seals there if they are starting to leak.
