3VZ-FE Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2008, 01:52 AM   #1 (permalink)
View C110GTR's Photo Gallery
3rd Generation 3VZ-FE Oil Leak
Hi
I just bought my 1st '93 Camry Ultima sedan
and its leaking a lil oil
here's some pics not sure what needs to be replaced or where the leak is coming from.
Please advice
Thanks
C110GTR is offline   Reply With Quote
Old 06-23-2008, 02:55 AM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
whats a camry ultima?
as for the leak, i would just clean it up as much as possible. then follow it til you find the source.
TheKevin is offline   Reply With Quote
Old 06-23-2008, 04:58 AM   #3 (permalink)
Its just like a Vienta Ultima is the top of the range camry model during that time
All electrics, leather seats, toyota security system, cd stacker etc...
there's just not enought space to really tell where the source.
Old 06-25-2008, 08:29 AM   #4 (permalink)
78transam's Avatar
View 78transam's Photo Gallery
Whenever my 93' Camry w/3VZ-FE leaked oil it was always from the valve covers. The front valve cover is easy. The back valve cover is accessible after you remove the intake plenum.
78transam is offline   Reply With Quote
Old 06-25-2008, 10:34 AM   #5 (permalink)
View whitefamily's Photo Gallery
3rd Generation
That will be the distributor shaft o-ring seal on the 3VZ. a common thing in that engine. An oil leak from the rear cam cover gasket does not appear in that location, it gets on the exhaust pipe instead and causes a distinctive smell !!
There is also a possible water leak in the 3VZ which can appear just there, so make sure it is not antifreeze which can also attract gunk and look a bit like fresh oil.
Cheers
whitefamily is offline   Reply With Quote
Old 06-25-2008, 10:43 AM   #6 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Buy some UV dye and pour on the oil, then with the kit you can see where the leak,
Ask for UV dye at the autopart store, that is how I have found some leaks on the camry
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
