stabilizer bar link - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2008, 01:19 PM   #1 (permalink)
View Richard_97LE's Photo Gallery
stabilizer bar link
anyone know how easy or hard replacing these are? Looks easy from the FSM, also what will I need to replace them, any bushing, what tools and since it was broken by a mechanic should I replace just the one broken side or both?
Richard_97LE is offline   Reply With Quote
Old 06-24-2008, 12:53 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if you're talking about the endlinks....theoretically they are easy. if you don't have rust.
if they're rusted on, then usually they have to be torched off, or you have to use a pair of vicegrips to grip where the bushing is so that you can turn the key. and lots of pbblaster as well.
HaHa
Old 06-24-2008, 12:51 PM   #3 (permalink)
it's the part that attatches to to strut assembly thanks for the response
Old 06-24-2008, 04:11 PM   #4 (permalink)
Gameroom cash: $303255
You only need to replace the one that is broken. Like Eye8Pussies said, spray it down liberally with a lot of PB Blaste, a couple of days before you attempt this. Spraying it and then driving the car helps the PB Blaster work it way in to things. Also, you will need a set of metric allen wrenches to hold one area while you turn the nut. You will know what I mean when you get the tire and wheel off and take a look. I did this on a 98 a couple of years ago here in the northern rust belt and after spraying a good penetrating oil and driving it for a couple of days, both sides (I was changing out the rear struts) came apart without a problem.
Mike
Mike Gerber is online now   Reply With Quote
