Well, first off, the item you have selected in that link corresponds to what it says is the 'lateral arm' which I believe is also called the suspension arm (correct me if I'm wrong).
Second, what component exactly is it you wish to replace? Just the shock absorber, the strut insert, the whole assembly?
Third; if you wish to distinguish between whether or not you have ABS, an easy way is to look into the engine bay...
If you have the silver box between the coolant and windshield washer fluid reservoirs on the bottom left-hand side of the photo with the 4 wires coming out of it, you have ABS. If the box is absent, you don't have it
EDIT: Just like the guys above said, except with a picture
[Sorry Venom, stole your photo
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
