Another Transmission fluid level thread. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2008, 05:42 PM   #1 (permalink)
View clodbuster's Photo Gallery
4th Generation Another Transmission fluid level thread.
I did a transmission filter change on my 98 2.2 (a140e) and I have a fluid level situation I’m not sure about. I added about 2.5 qts after replacing the filter and pan, drove around a bit to get everything up to normal operating temperature. When I checked the level it was barely showing on the dip stick so, I added some more and drove some more. I did this until I got the level between the two notches in the hot range on the dip stick.
Now the deal is, by the time I got it to this level, with the transmission hot, checking with the engine running, I had added a total of about 3.5 qts. I checked the level several times over a couple days in the same manner with the same results. But when I check the level cold (overnight) the level shows a little over the hot range. Instead of going down it is going up.
Any thoughts on this?
clodbuster is offline   Reply With Quote
Old 06-24-2008, 05:49 PM   #2 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
From what I understand, checking the transmission fluid level is a bit tricky compared to say, checking your oil level. What does your owner's manual say you need on a drain/refill?
I just drained everything out and refilled what my owner's manual said. It comes right up to the hot level after I've been driving for a while and it's right at the cold mark when I've just started the car. (This is on my gen 5.5 by the way - gotta do the gen 3.5 soon)
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 06-24-2008, 08:41 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You check your transmission fluid with the engine running and the fluid hot. Right before you check the fluid shift the transmission through all of the gears. If you drained out 2.5 quarts you should need 2.5 quarts. However, if you drained out less than that you may have been low on fluid before you started and now you are having to top it off.
Kep
Old 06-24-2008, 09:01 PM   #4 (permalink)
Kep
The above is exactly what I did. I did not measure what I drained out, I had already poured it into my collecting drum that I use for proper disposal when I realized the reading was not what it was supposed to be. I just went with the 2.5 qts. that I had read here and from what I was told at the auto parts.
Old 06-24-2008, 09:44 PM   #5 (permalink)
wtftoy's Avatar
View wtftoy's Photo Gallery
Start car, let it warm up and at normal idle. Shift through all the gears(let the gears engage then go to the next). I read somewhere on here that the level should then be at the Cold mark...I might be wrong, I'll double check somewhere.
1998CamryLEV6
Tokicos,Eibachs,TrdRSB,Intake,Jim'sTorqueRod.
wtftoy is offline   Reply With Quote
Old 06-25-2008, 04:10 AM   #6 (permalink)
Mine was in between cold and hot (right after changing it, didn't drive it yet). I thought I read somewhere that's fine. I checked it with the engine running and as you said, after I've cycled through all the gears once or twice.
moving forward
Old 06-25-2008, 01:22 PM   #7 (permalink)
Gameroom cash: $303255
"Right before you check the fluid shift the transmission through all of the gears."
Exactly. Warm up the car by driving it. Then park on a level surface and go through all the gears starting with LOW. Count to 2 and them move to the next gear. Go all the way up to PARK in this manner and then do the same thing going back down to LOW. Now shift back to PARK, leave the engine running and check the trans fluid.
Mike
Mike Gerber is online now   Reply With Quote
