harsh grinding sound upon acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2008, 11:28 AM   #1 (permalink)
View camry92v6's Photo Gallery
3rd Generation harsh grinding sound upon acceleration
Hey. I get this really annoying sound whenever I press the gas pedal. Kinda hard to describe. It's like a harsh grinding sound, like 2 pieces of metals are being rubbed together on a pan with boiling water inside. The kind of noise you frequently hear on old pontiac cars (from my experience). Like I said, it is only happening when I accelerate. As soon as I stop pressing, the noise goes away. The pressure I give doesn't matter. Of course if I floor it the sound will be loud and if I slightly press on it, then you will hear it a lot less. I simply mean that I hear this sound as soon as I rev the engine.
A couple of day ago it wasn't so bad. You could hear the sound for one second, then it disappeared for 3-5 seconds, rinse and repeat. But now it just won't go away.
Another problem. My engine keeps jumping from 600 to 1000 rpm (forth and back) when I am idle at a red light for example (still on D gear of course). Timing belt ?
The car is a 92 Camry with the V6 engine. Automatic transmission.
Thanks for your help.
camry92v6 is offline   Reply With Quote
Old 06-25-2008, 01:55 PM   #2 (permalink)
View tran.man48's Photo Gallery
well, I'm just a noob here, but I'll give you my 2 cents...
Does the sound occur when you rev the car in park or neutral? I would also check all your fluid levels.
Originally Posted by Zembonez View Post
Nothing is impossible with enough money and beer.
tran.man48 is offline   Reply With Quote
Old 06-25-2008, 02:03 PM   #3 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Might sound like a waterpump bearing about to go take a walk.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 06-25-2008, 02:51 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
can you get a sound clip of it?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
