Sludge cleanup/PCV valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2008, 02:11 PM   #1 (permalink)
Junkyard Junkie
Chris Crash's Avatar
Gameroom cash: $746337
iTrader Score: 10 reviews
I saw all the posts and threads about how much sludge is under the valve cover. So I was convinced to take mine off and have a look. It looks like this:
I figured I could seafoam it and that would help maybe? Or should I just tackle it with a wire brush and some spray-on cleaner? Or both?
Also, is this the PCV valve?
My question is, does this look bad? Should I bother cleaning it? Or is it all right the way it is?
Chris Crash is offline   Reply With Quote
Old 06-26-2008, 02:17 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
yikes ... looks like the infamous Gen 4 sludge ...
i would clean it up, because it hasnt developed to a point of no return - i wouldnt run seafoam in there directly, i would clean it up by hand as best you can
i would run seafoam through the brake booster line, or whatever intake routing you see fit, as normally done by a lot of us - that will just help with minor residue/carbon build up ... and i would make sure to stay on top of oil changes! keep track of the oils youre using and how often youre changing, the same goes for the filters
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-26-2008, 02:28 PM   #3 (permalink)
Junkyard Junkie
If I cleaned it by hand with a brush or something, wouldn't most of the pieces get lost? Should I have a vacuum handy when I do this to get all the bits and pieces?
Old 06-26-2008, 02:33 PM   #4 (permalink)
Venom_5's Avatar
you could use something like a shop vac to scoop up the pieces, or just be careful when you knock pieces off - be sure to catch them with your hands
btw, is it just me or does your oil level look alarmingly low?
Old 06-26-2008, 02:41 PM   #5 (permalink)
Junkyard Junkie
You know, it probably is pretty low. I haven't checked in a while. I totally forgot about that. The valve cover gasket leaks. Need to get a new one.
Thanks for reminding me.
Old 06-26-2008, 03:09 PM   #6 (permalink)
Venom_5's Avatar
go grab a VCG @ your nearest dealership ... i think they charged me a few bucks for mine, it couldntve been much because i paid in cash and i dont have much cash on me usually
and if you let the car run on low oil, or go 6000+ miles without oil changes, youre likely to build up more sludge
Old 06-26-2008, 11:23 PM   #7 (permalink)
Junkyard Junkie
Yeah, a VCG ran me about 20 bucks. Then a filter, oil, PCV valve and a few other things were another 20.
Thanks for all your help, man.
Old 06-26-2008, 11:44 PM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
There have been several posts on various methods of cleaning a sludged up engine. Your chipping method will work. Have a vacuum running and hold the hose right next to the piece(s) that you're chipping so they don't drop into the void. A wire brush might be a little too harsh but it might work. A stiff tooth brush (dental brushes are great) might be a little more conservative. Again, watch for falling pieces and, if you do use a wire brush, maybe even breaking bristles dropping into the engine.
Ghettosled ran a discussion on this very thing. There was a very good response to it with a lot of different ideas. Check out: i have sludge buildup with pictures - what to do? (56k iffy?)
Kep
Kep
Old 06-27-2008, 12:55 AM   #9 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Another thing with leaking oil. I've not had issues with my valve cover, but I was leaking oil from the oil filter assembly. Once I changed out to a new PCV I stopped leaking oil. Haven't had a chance to remove my front valve cover yet, but hoping if it's like the rest of the car for the most part, it'll be fairly clean.
cykaaro is offline   Reply With Quote
Old 06-27-2008, 01:18 PM   #10 (permalink)
Junkyard Junkie
The toothbrush didn't really too much. It got some big pieces off, but there's still a lot of sludge built up. Seafoam? Or could I spray something like carb cleaner or brake cleaner or some solvent like that or would that fuck up the engine a lot?
Old 07-01-2008, 11:28 PM   #11 (permalink)
cykaaro's Avatar
Not really sure what is best to use, but definitely research before you use a particular product. Last thing you want to do is make things worse for sure. Being cautious can be a good thing.
