auto trans being annoying... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2008, 02:51 PM   #1 (permalink)
Newbie
View 94cylcamry's Photo Gallery
Hey all, the car in question is my own 94 Camry LE 5SFE auto transmission.
Umm...the other day I was getting onto the highway, pulled to the end of the ramp, and realized there was nowhere to merge in. Stupid I know, I'm not the best driver. So I came to a stop, waited a bit, then when an opening finally came, I kind of floored it to get in. Pushed the pedal 3/4 of the way down, car was moving but not really...going fast. Pushed the pedal to the floor, same thing, I could hear the engine racing but the car wasn't really taking off. It sounded like it was almost redlining but I was looking at the highway, not the rpm gauge.
Anyway, I know to make it shift up sometimes you have to let off gas, so I did, the trans shifted right away and the car just completely....VROOM took off. Now that has hapenned a couple times when I've stepped on the gas suddenly, and it's sort of annoying because it's not what you are looking for when you have to floor it.
Does this happen with all 5SFE auto trans? Am I just a bad driver? Is there anything I can do to make the trans shift more smoothly, and when I actually need it to shift?
Thanks.
1994 Camry LE 5SFE
160,000 miles[12/2/08]
94cylcamry is offline   Reply With Quote
Old 06-26-2008, 03:24 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
sounds like somthing is goin bad in the tranny. maby shift solinoid or torque converter. any other symptoms?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
bigbird is online now   Reply With Quote
Old 06-26-2008, 03:30 PM   #3 (permalink)
Newbie
Hmm...nothing I can really think of. Is there anything in particular you are looking for? It's mainly just the...refusing to shift when the gas is hit suddenly. A friend of mine who was riding in the car said the car was shifting a little roughly a month or two ago...the thing is, this is my first car, so I have no basis for comparison. If it is shifting roughly, I haven't noticed myself.
EDIT: And though this probably has nothing to do with anything, the car shifts really roughly into reverse, and it vibrates a LOT in reverse. It vibrates at idle in drive also, but Seafoaming and replacing the one motor mount has cut that down. However, reverse is twice as bad.
1994 Camry LE 5SFE
Old 06-26-2008, 03:35 PM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
thats typical of the 5S-FE + autotragic ... the biggest mistakes Toyota made with our cars is the 1st gear, and the lack of a 5th gear
1st gear does nothing - what you described is typical, the only thing that helps me is the kick-back cable mod posted by Toysrme a few years ago ... and then 4th gear is fine, but revs too high at 80mph, so we need another gear there (stupid auto tranny)
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-26-2008, 03:37 PM   #5 (permalink)
Newbie
Hmm...is that the mod where you are changing the nut position on that cable near the throttle body? Or something different?
1994 Camry LE 5SFE
Old 06-26-2008, 03:44 PM   #6 (permalink)
Venom_5's Avatar
yeah ... another great WTF story:
mine was already changed by a Toyota dealership or outside mechanic, because when i went to go do the mod - it wasnt in its normal position, it had already been tightened up somewhat ... but ive been driving at least 4 years with it almost fully-tightened or whatever, and i like the extra kick you get from the improved shifting
people say its harder on the transmission, but if you know how to feather the throttle to manually control shift points (which i do out of instinct, dont ask why) ... then its not so bad, and i havent seen any signs of wear or failure over the last 4 years
but really, you just have to get used to your transmission - i know that there are times when i need to use ECT/PWR Accel for highway on-ramps or passing, and times when just putting my foot down will do the trick, and times when i should Disable O/D while going up hill, and times when the transmission will downshift properly
i have a lot of hate for A-series transmissions, but theyre not impossible to live with
Old 06-26-2008, 03:46 PM   #7 (permalink)
Newbie
I'll have to go find that guide again and try it...seems like an easy little trick.
1994 Camry LE 5SFE
Old 06-26-2008, 05:02 PM   #8 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Yeah, I noticed quite a lot of "Sometimes" with these trannies too. They're ok but you know....sometimes it shifts smooth, sometimes the downshifts are brutal, aahh sometimes.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 06-26-2008, 05:59 PM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $198580
View xtremeskier97's Photo Gallery
x2
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-26-2008, 06:43 PM   #10 (permalink)
Newbie
Haha, I'd forgotten about the ECT button. Is it ok to tighten the bolt AND hit the ect button? Or should it be one or the other?
1994 Camry LE 5SFE
Old 06-27-2008, 01:49 AM   #11 (permalink)
Dave's
View Dave's's Photo Gallery
I had pretty much the same thing happen as the OP on my '04 recently. Actually looked down to see if I'd somehow knocked it out of gear when it took off.
Dave's is offline   Reply With Quote
Old 06-27-2008, 01:56 AM   #12 (permalink)
Venom_5's Avatar
wont hurt anything ... they dont do the same thing
ECT tells the transmission to wait to shift until higher in the RPM band when youre giving it extra throttle
Old 06-29-2008, 02:42 PM   #13 (permalink)
Newbie
Hey, could this possibly help with how my ebay-intake kills my low end? I step on the gas and it just won't shift
1994 Camry LE 5SFE
Old 06-29-2008, 04:44 PM   #14 (permalink)
Super deluxe Happy member
Quicksilver300's Avatar
View Quicksilver300's Photo Gallery
with your first gear problem, how fast does the car get to in first? If I remember correctly mine gets up to 20-25mph before second. I would doubt the intake would affect anything, if the engine is revving up and not moving, it's the trans.
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
Quicksilver300 is offline   Reply With Quote
Old 06-29-2008, 05:42 PM   #15 (permalink)
Newbie
I'll drive awhile and check..it's fine normally, just when I hit the pedal suddenly that it decides it doesn't want to shift...I don't know...
1994 Camry LE 5SFE
