VERY high revs on starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2008, 04:21 PM   #1 (permalink)
Tedders's Avatar
View Tedders's Photo Gallery
3rd Generation VERY high revs on starting
When I start up my 93 SE, 6 cylinder, the engine zooms up to 2,500 RPM then settles down after that. Since that happens immediately when it catches, I'm concerned about no oil in the cylinders. And it just doesn't sound right.
Any ideas?
Drive laughing!
Tedders
Tedders is offline   Reply With Quote
Old 06-26-2008, 04:31 PM   #2 (permalink)
JvR
JvR's Avatar
View JvR's Photo Gallery
Sounds like a vacume problem.
Use some soap and search for a leak.
Is the airhose not broken?
JvR is offline   Reply With Quote
Old 06-26-2008, 04:42 PM   #3 (permalink)
Tedders's Avatar
3rd Generation Vacuum leak? Oh, no...
The air intake hose is new ( an aftermarket; a pain - in - the - a-- fit, too!). Any other hoses that it could be? There are sooo many, and they go sooo weirdly deep into the depths!!
Thanks,
Tedders
Old 06-26-2008, 05:06 PM   #4 (permalink)
JvR
JvR's Avatar
Because it was a a pain - in - the - a-- fit are you sure there is no leak?
I think it must be a hose or sealing before the intake.
Just use some foam and put it around a seam and see if there is a leak.
Goodluck! (it worked for me)
Old 06-26-2008, 06:56 PM   #5 (permalink)
Newbie
View 94cylcamry's Photo Gallery
So this started hapenning right after you installed the new intake hose?
The fact that it settles down after a bit makes me think that this isn't the problem, but I thought I'd share anyway. And I have the 4cylinder motor, not the 6 cylinder, so I don't know if this even applies.
But if your throttle body has the two cords going to it, I would check to see that those aren't pulled any tighter than they normally would be. When I had my stock airbox out, I reinstalled it wrong, accidentally stretching out one of the cords in the process. Started up the car and it was idling at 2k rpm. So I took out the pipe again, and reinstalled it making sure to route the wire to where it originally had been. Presto, problem gone.
I wonder if it's that simple though.
1994 Camry LE 5SFE
160,000 miles[12/2/08]
94cylcamry is offline   Reply With Quote
Old 06-26-2008, 10:49 PM   #6 (permalink)
View johnssarris's Photo Gallery
i also have a 1993 camry se 5 speed. when i start my car the rpm's are also pretty high above a normal idle speed. it freaked me out at first, plus it was kinda hard to drive the 5 speed with the engine tached up, so i took it to a mechanic that i've known for years. he checked it out and did something to my ecu. it still does it, but not nearly as bad. it immediately starts going down after i start it and takes no more than 2 minutes to idle normal. i think you'll be ok as long as it goes down pretty quickly and is drivable,
johnssarris is offline   Reply With Quote
Old 06-27-2008, 12:17 AM   #7 (permalink)
View Koan's Photo Gallery
my 96 Camry XLE does the same thing, revs high until warmed up. Mine is an automatic , so I make sure I get it into gear soon to load up the engine and keep the revs more reasonable. One could carefully do this w a 5 speed as well. I would actually bet it is not a vacuum leak if it goes away when the engine is warm.
Koan is offline   Reply With Quote
Old 06-27-2008, 12:09 PM   #8 (permalink)
JvR
JvR's Avatar
2500RPM is normal...
1500-1800 RPM sounds normal.
If you have a air leak i think the aic will try to compensate it.
But you can be right.
Have try to clean the trottle body (and sensors) with brake cleaner?
Old 06-29-2008, 02:18 PM   #9 (permalink)
Tedders's Avatar
Thanks, guys & gals.
This high rev happened after I cleaned the Throttle Body (as best that can be done while still attached). The revs go way up but come right down to about 1,00 RPM. This also happened prior to my attaching the new air intake hose.
Maybe I just have to live with it, but ~ 2,500 rpm at start is disconcerting...
Tedders
Drive laughing!
Old 06-29-2008, 09:27 PM   #10 (permalink)
Creeps228's Avatar
Gameroom cash: $274418
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
OK thats wierd it seem like theres too much air going in, something seems to be lose allowing the the outside air to rush in without passing through the air intake...IAC doesnt seem to be the culprit because if your had low idle it could be the IAC but high rpm your getting more the "ideal" air into the cylinders at idle... Best of luck to everyone...
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 06-29-2008, 10:59 PM   #11 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Mine does the same thing when I start it until it's warm then drops to 1000rpm's. I just thought this was normal [??] My jeep [I6 4.0L] always did the same thing. Ran on the highside until the engine warmed up and then all was fine.
What I don't like though is after running highway speeds and coming to a stop, the idle drops to about 750, then comes back to 1000. Not sure what that's all about.
cykaaro is offline   Reply With Quote
