99 Camry Keyless Remote Programming - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2008, 05:00 PM   #1 (permalink)
View broozkie's Photo Gallery
Hello all.. Just bought a 99' Camry LE, 4-cyl. Picked up an OEM key less remote: FCC : GQ43VT14T
I pulled out the mirror adjustment switch... according to other posts, says to jump out pins 2-10 however, my pin 2 is not in use. I'm now thinking I may have to try the other way w/ the "reset" button on my ECU. It looks like my ECU is behind the glove box.... would be easy to access if I knew how to remove the glove box. Could someone confirm how I should program this key remote... would like to make sure before I go taking things apart to access the ECU (assuming that the ECU is behind the glove box) Any info would be of great help... thanks! D~
broozkie is offline   Reply With Quote
Old 06-26-2008, 06:46 PM   #2 (permalink)
View toyomoho's Photo Gallery
http://rav4world.com/forums/viewtopi...f9dad2dc3b4f4d
Same for this year/model car having this system.
Old 06-26-2008, 08:38 PM   #3 (permalink)
No ECU under my seat(s)..... Looks to be behind glove box.... any idea hot to remove the glove box w/out busting any plastic up ???
Old 06-27-2008, 01:16 AM   #4 (permalink)
There is supposed to be a plastic door finish panel that can be pried off. Once off you may need to disconnect the airbag wiring connector then remove the 4 screws the hold the box in.
Don't turn the ign on with airbag connector unplugged or you will get a SRS trouble light.
Old 07-22-2008, 11:15 PM   #5 (permalink)
[quote=broozkie;2386626]Hello all.. Just bought a 99' Camry LE, 4-cyl. Picked up an OEM key less remote: FCC : GQ43VT14T
OK... I removed glove box & pulled the ECU out. No reset button to be found on it, even opened it up & searched the circuit card...no reset or jumpers.
** Per my 99 factory owners manual... the correct FCC code is GQ43VT7T. I purchased the correct one & still no luck programming when doing the open driver door, lock & unlock 5 times, close door put key in ignition... ect ect. Does anyone out here have a good working programming sequence? I'd hate to have to take it to the dealer but looks like my options are running thin.
** FYI... not sure if this may be an issue, but my ignition key is not OEM..appears to be an after market. Also, when doing the lock & unlock sequence... my drivers door lock sticks and does not always complete the cycle...have to assist it manually. Any takes? Any help would be greatly appreciated! Thanks, D~
Old 10-28-2008, 06:42 PM   #6 (permalink)
aashish.paul's Avatar
View aashish.paul's Photo Gallery
Getting to ECU
Hi,
I too have a RS3000 dealer installed unit on my 99 Camry. I wasnt able to get the glove box open to program the ECU.
I tried unscrewing the 3 screws on top of the glove box and the two under it but it didnt come off. I didnt want to force it out for fear of not being able to set it back. Can you tell me how you got to the ECU.
Thanks,
Aashish.
aashish.paul is offline   Reply With Quote
