Popping noise when shifting gears? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2008, 07:34 PM   #1 (permalink)
TN User
Nevalite's Avatar
View Nevalite's Photo Gallery
Hey,
Lately I have noticed that sometimes when I shift gears, not always, but usually from 1st to 2nd I hear a popping noise... It seems to happen mostly in the low gears.
This is on a 1992 I4 Manual Camry, what could be causing this?
Thanks!
1992 I4 Manual Camry - 294 000 Km and going strong.
1000W RMS in the trunk :P
Nevalite is offline   Reply With Quote
Old 06-26-2008, 10:06 PM   #2 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
is it when you move the stick from 1st to 2nd?
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 06-26-2008, 11:25 PM   #3 (permalink)
Junkyard Junkie
Chris Crash's Avatar
Gameroom cash: $746337
iTrader Score: 10 reviews
I've noticed on mine it kinda pops from 1st to 2nd. But it sounds and feels like it's in the shift linkage. And then 2nd to 3rd and 3rd to 4th are kinda splunchey crunchy noises.
Chris Crash is offline   Reply With Quote
Old 06-26-2008, 11:52 PM   #4 (permalink)
samarai912's Avatar
yeah its going out man. I had the same thing on my corolla sr5. the linkage needs to checked and so does everything else on it if you want to save it. its mainly the sinqs going out.
Old 06-27-2008, 04:58 PM   #5 (permalink)
TN User
Nevalite's Avatar
Usually just a pop from 1st to s2nd, rest of the gears seam fine. Ocasionally I get a pop from 2nd to 3rd... Never 3 to 4 or 4 to 5.
What needs to be checked or replaced? Whats causing this? Is it expensive?
Old 06-27-2008, 10:00 PM   #6 (permalink)
View Novice_cardude's Photo Gallery
Is it when you move the actual shifter, or when you clutch in or out?
If it's when you move the shifter, you probably have a bad bushing, or the joint the shifter pivots on may need lubricating. Usually when the synchros in the transmission start going out, you will hear grinding noises and/or the car will not want to go into gear.
If it's more when you clutch in or out, especially when you dump the clutch or just stay in the gas a little as you clutch in or out, you might have a motor/transmission mount issue.
'96 4cyl 5spd Camry
135k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 06-28-2008, 09:43 AM   #7 (permalink)
View Kurhas's Photo Gallery
mmm
it could be the wheel bearings, i had a similar prob lately, popping sound during take off, changing to 2 and 3 gear. without jacking the car. just grab the top of each tire and shake it, in and out with force.If you hear a clunking or clicking you've got a problem.
hope it helps
Kurhas is offline   Reply With Quote
