Battery light and blown bulb indicator light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2008, 09:35 PM   #1 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
Recently on/off when I hit my brakes the battery light and the blown bulb indicator light illuminate until I take my foot off the pedal. What could this mean? I guess the battery light flickering could maybe mean a voltage problem or something wrong with the batt/alt. But i'm confused why both would light up/go off at the same time? Anyone have a clue?
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 06-26-2008, 11:59 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I haven't seen this where it only happens when you apply the brakes, however, when those lights come on together it usually is a sign that the alternator is going. Take it in to a shop to have the alternator checked. Call around, often part stores (Auto Zone, O'reilly) will do this check for free.
Kep
Old 06-27-2008, 09:43 PM   #3 (permalink)
Durrby's Avatar
^Thanks for the reply. I'll get the alt looked at sometime soon.
Anyone else? I mean 30 muffler/exhaust/suspension threads get started a week all with responses but this thread goes overlooked?
Old 06-27-2008, 09:48 PM   #4 (permalink)
NBBADTOYS
View keisuke's Photo Gallery
check the 3rd brake light mine did it too and that was the problem the bulb had burned out
1997 Toyota Camry XLE V6- 308500 and counting
keisuke is offline   Reply With Quote
Old 06-28-2008, 01:27 AM   #5 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
Same thing happened to me and mine turned out to be the alternator going, so I'd definitely get that checked out.
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
Old 06-28-2008, 09:13 AM   #6 (permalink)
NBBADTOYS
get a friend and a volt meter and check the batter voltage vhile the car is running and not voltage should be 14ish - on 12ish off and then hit the brake to see if u have a drop might be a bad battery cell too
Old 06-28-2008, 04:53 PM   #7 (permalink)
Durrby's Avatar
Thanks guys. I guess it's the alt cause the battery is a brand new Optima Yellow top. I'll go to Autozone when I get a chance to.
Old 06-29-2008, 10:06 PM   #8 (permalink)
Durrby's Avatar
Well I had the alt/battery checked today and their both fine. WTF??? What's next to check?
Old 06-29-2008, 11:27 PM   #9 (permalink)
NBBADTOYS
as for the rear lights did u check ut third brake light those like to burn out or short
