erratic idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2008, 11:44 AM   #1 (permalink)
View JerryGiese's Photo Gallery
erratic idle
I have a gen 3 camry with a 4 cylinder engine. When I start the car, it revs up to 3,500 rpm. Then the idle fluctuates between 1,000 and 2,000 rpm. Any ideas what the problem could be?
JerryGiese is offline   Reply With Quote
Old 06-28-2008, 11:54 AM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
try cleaning the IAC and/or throttle body. i hope it helps
TheKevin is offline   Reply With Quote
Old 06-29-2008, 01:46 PM   #3 (permalink)
Gameroom cash: $303255
In addition to cleaning the idle air control valve and the throttle body, check for a vacuum leak.
Mike
Mike Gerber is online now   Reply With Quote
Old 06-29-2008, 04:26 PM   #4 (permalink)
View Camry-rulez's Photo Gallery
When I start my engine (3VZ-FE) it revs up to 2000rpm and than goes down to 900rpm. is that normal?
Euro CAMRY. 3.0 GX V6 (auto.) 1993'
Toyota Camry and Peugeot 205 Driver
Camry-rulez is offline   Reply With Quote
Old 06-29-2008, 08:49 PM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
View Creeps228's Photo Gallery
Camry-rules, is it exactlly at 2K, because normla spped RPMS are around 1800 through approx. 2 Grand, and then gradually decrase it about 900 RPMS then yes that seems to be normal
Jerry 3.5K RPMS something is lose you can also check you Exhuast Recirculation Gas System you maybe be getting too much exhaust gases during idle entering the cylinders maybe, im not sure
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
