Airbag light, power steering belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2008, 03:59 PM   #1 (permalink)
Tech In Training
View Gun5's Photo Gallery
Well After doing almost every seal and the CV axles/seals on the tranny the airbag light is on the dash any connections I might have hit?
also the power steering belt keeps rubbing the timing belt case it was doing before all the new belts and such all the pulleys are straight and such
Ryan
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
Old 06-28-2008, 05:24 PM   #2 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
timing belt is inside the engine, so the power steering belt CANNOT be rubbing against it. you're probably referring to the alternator belt.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-28-2008, 07:02 PM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
For the airbag light, just retrieve the code instead of hypothesizing as what it could possibly be. That will set you on the right path.
For the ps belt, is the timing cover secured all the way? Make sure that all the 10mm bolts around the lower perimeter are present and secured.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 06-28-2008, 07:44 PM   #4 (permalink)
View Albuynp Ryeno's Photo Gallery
how do u check airbag light codes?
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Old 06-28-2008, 08:31 PM   #5 (permalink)
Tech In Training
ment timing belt cover was talking while typing... yes the cover sits flush and is secure it did it before I did all the work and is doing it after... belt is still slipping too when you turn the wheel I'v tightened it twice..
