Usually, when I install extra equipment like fog lights, horn, or stereo, I run the positive lead through the firewall. In most cases, I try to go through where there's an unused rubber grommet or where wires already are coming through the firewall. I connect the wires either right to the battery or to the main fuse box. I do use a fuse, the lights you're buying probably come with one. 15amp should be fine. For the ground wire, I just find a close spot around the device(your lights) like the frame, somewhere under the dash, as long as it is directly and cleanly connected to the car body/frame, you're good to go.
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
