Help Me Please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2008, 11:56 PM   #1 (permalink)
dabshr's Avatar
View dabshr's Photo Gallery
4th Generation Help Me Please
I bought this stupid car (1997 Camry LE) 2 months ago, I put a crank kit into the 5SFE and then the radiator blew and spun a rod bearing. I pulled that engine and bought a Reman, So, Reman, new water pump, new oil pump, new cam sensor, new plugs, new wires, new 2-3 coil, new alt, new timing belt, new pcv, Installed engine every thing went together well, I crank the car up and very bad idle, I have to feather the gas to keep it running, all plugs are sooty, black smoke from the tail pipe, misses at all rpms, shows no codes on my scanner, no fault lights, Temp sensor OHM check is good IAW Chilton. I am at a loss and at the end of my rope. Any suggestions would be helpful, anything, If someone can describe the engine management system to me that could be helpful! Please Respond!:c onfused:
1984 CJ8 360AMC 39.5IroKs
1997 Camry LE 2.2 Stock
2000 F250 Powerstroke 7.3 6Spd Edge
dabshr is offline   Reply With Quote
Old 06-29-2008, 01:44 AM   #2 (permalink)
Australian TN'er
View Phat Devil's Photo Gallery
After resetting the CPU it always idles like crap though. Last time i did that, my car did that too. But i'm not sure about the sooty plugs or smoke though.
Whine addiction!
Phat Devil is offline   Reply With Quote
Old 06-29-2008, 12:30 PM   #3 (permalink)
dabshr's Avatar
4th Generation
So, How did you get the cpu to operate normally?
Old 06-29-2008, 12:36 PM   #4 (permalink)
engineer in training
Gameroom cash: $145055
double check the map sensor and surrounding connections, thats my only guess. I hate problems like these that don;t throw any codes or give any clues, best of luck!
Old 06-29-2008, 08:32 PM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
check to see if your IAC port is clogged, adn btw i dont konw what sooty means kinda lost there. ANyways how bad is your Idle rpms
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 06-29-2008, 11:46 PM   #6 (permalink)
dabshr's Avatar
4th Generation
You know soot, soft black carbon type substance, when an engine runs rich (too much fuel) the exhaust smoke is black, and the spark plugs are covered with black carbon.(fuzzy looking soot)
My diesel exhaust pipe look just like it, all black and sooty!
The car wont idle at all, turn the key it fires up then dies, you hold the pedal half way or so, then it will run @ about 1100 rpm, if you floor it, revs up with a miss.
Old 06-30-2008, 08:54 AM   #7 (permalink)
Creeps228's Avatar
^ OK i got it now, i would have thought it would be spelled differently.
You can also try to seafoam it, clean it up off all carbon inside, well some because seafoam wouldnt get all of it
MR2: 7A-GE
Old 06-30-2008, 01:06 PM   #8 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Sounds like the A/F ratio to me.
Chris Crash is online now   Reply With Quote
