leaks = so frustratin!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2008, 07:16 PM   #1 (permalink)
conkers15's Avatar
View conkers15's Photo Gallery
i have an oil leak so i replaced the valve cover gasket.
i replaced camshaft o right
new water pump
distributor o right
where else can it leak?
conkers15 is offline   Reply With Quote
Old 06-29-2008, 07:35 PM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
front seal?
TheKevin is offline   Reply With Quote
Old 06-29-2008, 07:36 PM   #3 (permalink)
conkers15's Avatar
front seal... please tell me where that is hahaha
im really newb at my Camry
Old 06-29-2008, 08:28 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
crank shaft, oil pump, oil pan...
you need to track down what is actually leaking instead of just taking guesses. you will save time and money this way.
Old 06-29-2008, 08:32 PM   #5 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
here is the list to check, or maybe replace
cam shaft seal
crank shaft seal (front seal)
oil pump seal
valve cover gasket
oil pan (gasket = silicone)
oil pump housing o-ring
most of the parts above is around $10 each, but just labor intensive.
i've seen tranny oil pan leaking, axle seal leaking and the worst nightmare, rear main seal leaking.
bronzemaxell is offline   Reply With Quote
Old 06-30-2008, 01:45 AM   #6 (permalink)
conkers15's Avatar
well it smokes enough to see it come out from the engine bay.
theres a tiny tiny leak in the back of the valve cover gasket. would that create such a smoke?
how would i track the leak myself?
Old 06-30-2008, 01:49 AM   #7 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
any bit of hot oil, small or large, touching the hot surface of the engine will smoke.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-30-2008, 08:05 AM   #8 (permalink)
conkers15's Avatar
how do i check where a leak is originating?
Old 06-30-2008, 11:45 AM   #9 (permalink)
ghettosled's Avatar
degrease the engine to remove all of the old oil caked to the outside. then run the motor and see where the the fresh oil is leaking. you can also buy a dye, pour it into the motor and use a UV light to see where the dye is showing up.
Old 07-01-2008, 12:45 AM   #10 (permalink)
conkers15's Avatar
well its very hard to clean the oil off the back of the engine because thats where its all leaking... how do i clean it/ reach it?
also... my exhaust pipe is covered in oil? i dont know what its called maybe the muffler? what kind of leak will cause oil to drip there?
