hi everyone
i have a 2000 v6, i made an exhaust system without a catalytic converter and i made a hole for the sensor after the catalytic converter... so the car should work fine and the check engine signal shouldn't appear right?
after 5 hours of driving, the signal appeared!
i took the battery off for a couple of minutes then i pluged it back, the signal was off... fife hours later it appeared again!!!
what's the problem? how can i fix it (without having to use a catalytic converter)? and will this affect the car's performance by altering the ignition timing??
thanks
note : after the exhaust system the car lost 4 seconds going from 0 to 110mph... AWSOME
