Get something to prop the hood up and remove and replace one strut at a time. My 95 had one bolt at each end. One of mine had a wire plug connected that needed to be removed and then remounted. If you buy exact replacements it is easy. Some of the after market brands require you to use the old struts' mounts. To do this you may need to drill out the old studs. Not particularly difficult but it's a lot easier getting new struts with the appropriate mounts already attached. This may not be an issue with the newer models but look into it before you buy your replacements.
Kep
