strut bar ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2008, 11:21 AM   #1 (permalink)
SLAMCAM56789
Luke4567's Avatar
View Luke4567's Photo Gallery
strut bar ?
ok my strut bar came in but the bolts you have to loosen to connect it are so damn tight i can't get em loose i have used a wrench and sockets to get it loose still won't come loose, and the other problem is the its like it won't stretch to the other side the sway bar
Luke4567 is offline   Reply With Quote
Old 06-30-2008, 11:27 AM   #2 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Sounds like you have the wrong strut bar if it doesn't extend to the next bolt pattern. as for loosening the bolts make sure you are using a six point socket then use a large cheater bar to budge em loose. My 1991 celica gave me the same problems.
Blane is offline   Reply With Quote
Old 06-30-2008, 11:30 AM   #3 (permalink)
SLAMCAM56789
Luke4567's Avatar
Old 06-30-2008, 12:13 PM   #4 (permalink)
SLAMCAM56789
Luke4567's Avatar
what i meant to say was the strut bar was for the models 92-96 i emailed the guy hopeing he sent the right one, umm but i got another ? how big a diff when i drive am i gonna be able to tell about the strut bar?
Old 06-30-2008, 01:25 PM   #5 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
I don't think you will notice a huge difference at all. Do what he said above and use a large breaker bar for it. Make sure to torque the nuts back to spec. Just a general question to anyone... Does the spec change when you add that on?
Admiral is offline   Reply With Quote
Old 06-30-2008, 01:46 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
measuring tape?
Some strut bars have the ends threaded to the strut tower mounts, to adjust for span, is your that type?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-30-2008, 03:46 PM   #7 (permalink)
SLAMCAM56789
Luke4567's Avatar
yea it will reach to each side now the problem is the black sides on each side won't go into the bolts they don't line up i dont get it
Old 06-30-2008, 07:02 PM   #8 (permalink)
View bigbluemonkey502's Photo Gallery
its cause ur body has warped over time. if its too long jack ur car up from the center on the k frame of its too short jack it up from the side and you should be able to get that little bit you need to get it on there
bigbluemonkey502 is offline   Reply With Quote
