"Knocking"sound when braking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2008, 06:56 AM   #1 (permalink)
View 94_v6_camry's Photo Gallery
3rd Generation "Knocking"sound when braking
Guys,
Everytimes when i apply the brake it would make this knocking noise...any ideas what i be looking at before taking to my local mechanic ???
Derrick
94_v6_camry is offline   Reply With Quote
Old 07-01-2008, 08:59 AM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
probably need to resurface your rotors
TheKevin is offline   Reply With Quote
Old 07-01-2008, 09:38 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
There are some spring clips (anti-rattle clips???) on each side of the brake pad where it's captured in the caliper assembly. Those springs sometimes break. That could be the source. If it is, that would be a cheap fix.
Or a brake pad could be coming apart, with the friction material separating from the steel backing plate. I had that happen once and it made some weird noises.
Or you could have a bad wheel bearing or a bad CV joint. Could be a lot of things.
BMR is offline   Reply With Quote
Old 07-01-2008, 05:12 PM   #4 (permalink)
_
Gameroom cash: $221635
View uuuuu's Photo Gallery
Check your trunk or under your seats for loose objects?
uuuuu is offline   Reply With Quote
