power steering fluid/engine coolant/ dome lights!
so yesterday i was using my ac and then i went home. when i was going back to my car i noticed a puddle on the right side of my car. it was watr texture, and slight brown. i checked the engine coolant, and i realized its nearly empty. was the dripping from the coolant, or just like water condensation do you think? also, should i put the engine coolant in the yellow colored plastic reservoir, or in the radiater itself? i cant tell how empty the radiater is.
and my dome light doesnt work anymore. i opened up my fuse box and looked what fuse was for the dome light, it said 20. i looked at the fuse and it was fine. however when i took it out, i noticed my clock or radio didnt work. so im not sure if its for the domelight or not..? and i checked the bulb, and it was fine. so did i get the wrong fuse? or did i do a short circuit some time ago? (its been broken for awhile) if it is a short circuit, is that easy to fix? how do i do that?
my car is a95 camry v6
p.s. nevermind the fact that the thread title mentions power steering fluid
