Nothing to be concerned about.
That upper trim strip is held in place with five plastic "butterfly clips". Odds are that one clip (maybe more
than one) has broken.
The catch is, it's not easy to replace that because the clips were originally seated in very soft fresh window
sealant immediately after the window was installed. After years and years, the sealant is very well set and
quite hard, relatively speaking. The new clips (if you replaced them) would not seat deeply into the
sealant like the old ones did, for that reason. So the trim strip won't go all the way down into place and
stay down.
Been there, done that, got a little frustrated. The clips are SLOWLY seating themselves fully, but only
because the car is black and the hot Florida sun is heating it up enough to soften the window sealant
enough for the clips to slowly dig in like they should.
CJ
