The Camry is out of comission, seems like the water pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2008, 09:49 AM   #1 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
4th Generation The Camry is out of comission, seems like the water pump
Puddle of coolant under the car, the tiny weep hole near the thermostat is...well....weeping. The bearing had been making noise for a while.
If it wasn't for the fact that I've never removed a timing belt before I'd try to DIY it but I'm not confident enough....
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 07-06-2008, 10:09 AM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Ive never done it before either, but it doesnt look difficult. With the number of DIYs on this forum pertaining to the water pump/timing belt, you should have no problems!
FIX IT!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 07-06-2008, 10:38 AM   #3 (permalink)
DIY : I believe
Maim Menu's Avatar
I know, but my timing belt would be good for another 20 000kms, wich is now more than a year for me. I moved out of the rented house to an appartment complex that is WAY closer to my job, problem is now all mechanical stuff will be done in a parking lot, wich will require more careful planning.
If I do it myself, I don't plan on getting a new timing belt.
1. Could I move the Timing belt out of the way to just change the water pump?
2. Do I absolutely have to drain all the coolant from the engine to do it? I do expect some spillage, I just don't know how bad it's gonna be.
If the spillage is manageable, I could park the car over a blanket and change the water pump without even jacking the car up, and that'd be great.
These are basically the two things that I need to know to take a decision.
Old 07-06-2008, 08:07 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
1. the timing belt has to be removed. might as well spend the extra $30 and slap on a new belt.
2. i didnt drain the cooling system when i changed my water pump. i think i spilled about not even a half gallon. i caught most of it in an empty used oil catch can.
