help with upgrading brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2008, 04:33 PM   #1 (permalink)
chill
View 97Killa CAM's Photo Gallery
4th Generation help with upgrading brakes
I have a few questions about upgrading brakes on a 1997 camry. If anybody on here has tried it and could tell me a few things I'd really appreciate it. I have a 4 cyl. camry and want to know if upgrading to the v6 brakes or getting drilled and slotted rotors would help. I have 20" rims on it so i need to upgrade soon.
97Killa CAM is offline   Reply With Quote
Old 07-07-2008, 05:38 PM   #2 (permalink)
Young Toyota Tech
View Turboman412's Photo Gallery
what tires did ur car come with stock? 14 or 15? if you had 15's you will have a bigger caliper then then 14. u should look into a lexus gs300 of simular year to your car ( or body style). that car comes with stock 2 pistons calipers. i really dont see why the caliper wont bolt up. if it dosent u can always just swap nuckels and it would work.
good luck
Turboman412 is offline   Reply With Quote
Old 07-11-2008, 03:36 PM   #3 (permalink)
JvR
JvR's Avatar
View JvR's Photo Gallery
Is this true ,Can i use a 1998 calipers for my V6?
http://en.wikipedia.org/wiki/Lexus_GS
JvR is offline   Reply With Quote
Old 07-12-2008, 03:47 PM   #4 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
yeah the brakes from 92 -01 use the same spindle so the front calipers are swapable!!! good stuff because I actually did it on my car, I our suspension set up is the same aswell, I also have rear calipers on my 4th gen. I got the calipers new, but you're going to need a piece called a rear axle carrier that will allow you to bolt up the calipers in the rear!!!! Good luck bro. let me know if you need any help
megamac83 is offline   Reply With Quote
Old 07-12-2008, 03:56 PM   #5 (permalink)
View Albuynp Ryeno's Photo Gallery
i should be able to do this mod on a gen 3 v6 as well, right? So i need 4 calipers and both rear axle carriers?
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
