'99 Camry (4 cyl.) PO110 Code - Need Ideas
I would like to hear from those who have dealt with this code and what remedies solved the problem. I know what the code points to and have replaced the IAC sensor. Did not seem to help. What test is there for the wiring to this sensor? I have a voltmeter.
I am also wondering if these cars have any history of ECU failure, called PCM in Haynes manual.
My symptoms are intermittent idle hunting, some occasional blowing of blue smoke at start-up, will drive fine but is a threat to die when stopped, with difficulty restarting. At times will only restart after sitting several hours.
Could a carbon-clogged vacuum line be a culprit? Clogged injectors? One mechanic suggested the MAP sensor but that's a different code, right?
Please toss out any ideas, please! Thanks - Jim
