Tires are locked!!! Help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2008, 08:45 PM   #1 (permalink)
View aebepe@hotmail.com's Photo Gallery
We put new tires on my 92 camry ourselves. The car is new to me, and no owners manuel came with it. I tried to drive it and discovered it won't move. It starts, the gear shift moves, but won't register the gears or move the car! What to do?????
aebepe@hotmail.com is offline   Reply With Quote
Old 07-07-2008, 09:30 PM   #2 (permalink)
Electronics master
View cmjohnson's Photo Gallery
Did you put on new rims or just new tires?
IF you put on new rims, they may not be compatible with the car and are locking up on the brake assemblies or something.
I'd check that FIRST.
Second option is a problem with the shifter cable to the transmission.
A serious transmission problem is possible but not likely.
CJ
cmjohnson is offline   Reply With Quote
Old 07-07-2008, 10:37 PM   #3 (permalink)
pro nub
View trdcamry00's Photo Gallery
I don't know how your tires are stuck. Are you staying you are stuck in park? Is this your first time driving the car and the car won't shift into gear or this just happened to you after driving. Do your gauges work? My car would shift through the gears but was stuck in park. I had a problem like this and my cluster wouldn't work so I checked the fuses under the dash and sure enough it was a blown fuse. good luck
trdcamry00 is offline   Reply With Quote
Old 07-07-2008, 11:23 PM   #4 (permalink)
View toyomoho's Photo Gallery
Check that the shifter cable is actually moving the gear selector on the trans. You will be able to see this with the hood open.
Jack up the front/rear tires and determine if they rotate when off the ground.
Old 07-08-2008, 12:43 AM   #5 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
kind of a long shot but it could also be seized calipers, no?
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 07-08-2008, 12:50 AM   #6 (permalink)
It's pronounced "Nesquik"
View N35QU!K's Photo Gallery
hmm... e-brake?
Click image for vehicle info (UPDATED 12.01.09)
N35QU!K is offline   Reply With Quote
Old 07-08-2008, 01:40 AM   #7 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
im going to assume you started the car first...
rebel8ball is offline   Reply With Quote
