Stupid screw wont come out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2008, 11:53 PM   #1 (permalink)
critical nyy fan's Avatar
View critical nyy fan's Photo Gallery
4th Generation Stupid screw wont come out
I got a 97 camry le v6 and the D gear light on my dashboard blew out the other day so i bought a new bulb for it from the dealer. Thing is one of the screws is stuck. Its one of the two screws facing down that holds on the black trim around the dashboard and the clock. I tried everything from an impact screwdriver to all sorts of wrenches and screwdrivers combinations but it wont budge. Anyone got any suggestions
critical nyy fan is offline   Reply With Quote
Old 07-09-2008, 12:02 AM   #2 (permalink)
i was thinkin maybe i can go to a local shop and charge me maybe 10 bucks to get the screw out
Mods: Blue wiper blades, Blue LED windshield washer nozzles, 6000k Xentec HID's, Blue interior dome light, Purple glovebox light, Blue trunk light, "3A Racing" exhaust tip, Pioneer 6900 deck, Alpine Type S speakers, and a Alpine V-Power F300 amp.
Old 07-09-2008, 12:15 AM   #3 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
thats odd that the screw is stuck. its stuck right? not stripped. never had that problem.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 07-09-2008, 07:03 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
your last option is to drill it out.
Old 07-09-2008, 11:10 AM   #5 (permalink)
i used a drill with a philips bit already no luck
Old 07-09-2008, 11:17 AM   #6 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
ghettosled said to drill it out with drill bit,
does the srew has head for a socket?
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 07-09-2008, 01:12 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I'm with Samarai912, is the screw spinning around but not coming out (stripped) or frozen?
Kep
Old 07-09-2008, 11:41 PM   #8 (permalink)
its not stripped its just so tight in there i tried a drill but no use its too tight w.e not a big deal ill live thanks for tryin guys
Old 07-10-2008, 12:37 AM   #9 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
used a drill and cant get it out, wierd, those botls shoudnlt be on tight at all they screw into plastic. BUt what kind of drill you using, id suggest get a cordless drill with a 19.2V battery fully charged it shoudl be agble to get it out
best of luck
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 07-10-2008, 01:16 AM   #10 (permalink)
View djb2's Photo Gallery
Sears has a "bit out" set that works really well on stripped screw heads.
I've replaced that light myself, but didn't have any problem with the screws.
djb2 is offline   Reply With Quote
Old 07-10-2008, 06:52 AM   #11 (permalink)
ghettosled's Avatar
those screw extractor kits should take care of it. basically you drill a pilot hole with a bit in the screw. then there is a cone-shaped gripper thingie that screws into the hole and keeps gripping harder until the screw comes out. this screw shouldnt give any problem coming out.
Old 07-10-2008, 09:11 AM   #12 (permalink)
With the Sears set you don't have to drill a pilot hole. It's triangle shaped with biting edges. I'm usually a skeptic, but it's a tool that has worked in cases where I didn't expect it to. Worst case is that it just eats the head off and you can remove the rest when the cover is off.
If you do drill, use a left-handed bit.
Old 07-12-2008, 11:45 PM   #13 (permalink)
that guy
View xylium's Photo Gallery
Mine got stuck too but not that bad. I simply put one hand on top of the dash on top of the cluster and used the other to apply force with the screwdriver (too much flexing) and then it came out. I imagine you tried the same thing but I thought I'd add my two cents.
Totally stock 00' 4cyl in Sage. Looking for set of nice stock 15" alloys for cheap, got any?
xylium is offline   Reply With Quote
