Greetings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2008, 01:54 PM   #1 (permalink)
View HotUnderTheCollar's Photo Gallery
USA Greetings
Hi,
I just joined today so that I can get help with one of my Toyotas. I currently have 3 of them - a 1989 Pickup 4-banger, a 1997 Camry XLE V-6,
and a 1999 Solara SLE V-6.
I don't know much about this blog / forum stuff, so I hope I'm putting this in the correct spot.
I am having an airflow problem with the 97 Camry. When the control is set on either "Panel" or "Bi-level" I get a very low airflow through the two vent above the radio. The two vents by the door seem to have proper airflow*.
In all other positions, the airflow seems to be working correctly.
The air outlet servo motor looks like it's working correctly, but apparently it's not opening a door inside the ductwork. I cant tell because the damper plate is in the way of seeing what the linkage is doing.
So, how do you remover the damper plate? Is that a wise thing to do - or will the linkage fall all over and be a pain to put back together?
Thanks. Any suggestions will be appreciated.
* Compared to the Solara, which has the automaic air controls, and a five speed fan instead of a 4 speed, the overall air flow on the Camry is terrible - like the fan in the Solara on the middle setting provides much more airflow than the Camry on high.
HotUnderTheCollar is offline   Reply With Quote
Old 07-10-2008, 02:06 PM   #2 (permalink)
Moderator
Gameroom cash: $568537
View silver04rollas's Photo Gallery
Welcome to TN.
I see you have a few questions about an issue with your Camry. It would be best to have this thread in the Camry forums so that you will get a lot of helpful responses over there.
MOVED!
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 07-10-2008, 10:25 PM   #3 (permalink)
Thanks for moving me to the right place. I thought I found some info under "center vents - no air" but I guess that only applied to earlier camry's... i will keep searching for an answer, hoping one shows up!
