need help help asap!! EGR???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2008, 07:22 PM   #1 (permalink)
View OSIDE13's Photo Gallery
recently failed smog test.To which I had code for sytem too lean bank 1. Changed o2 sensor problem solved soon after code 0401 egr flow insufficent. I changed the egr valve checked hoses and code came back. then cleaned egr modulater filter no help. I went aheah and changed the vsv behind the block and the code came right back. What else can I do to resolve this problem????
OSIDE13 is offline   Reply With Quote
Old 07-10-2008, 07:42 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
REPLACE the EGR modulator itself, not just clean the filter. Creeps228 here had the same issue. and did the SAME ecaxt things. We then replaced the Modulator, and bingo, no code. I'd say it will be the same for you, then you should be good to go for the retest.
5 Lug Corolla WHAT?
Old 07-11-2008, 10:56 AM   #3 (permalink)
Thanks Ill try that, I was going off of everyone else who kept saying it was the vsv. hopefully this works Gotta get this car registered.
Old 07-11-2008, 11:27 AM   #4 (permalink)
The Modulator has a diafram in it which apparently gets sooty and clogs up, which hampers the airflow. My friend was told the same thing with the VSV, then the Valve, and the only piece left was the Modulator. We took a quick run to the dealer (they often have them in stock), and got one. I think $60. But not 100% sure. Let us know if it works. Those are the only 3 main pieces of the system.
5 Lug Corolla WHAT?
Old 07-11-2008, 01:44 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Also verify that the hoses connecting the EGR and the modulator are clear. The bottom one on my 3SFE clogged up with carbon once.
Kep
