Thinking of buying a 97 Camry LE...questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2008, 09:40 PM   #1 (permalink)
View Agrippa's Photo Gallery
Im thinking of buying a 97 Camry LE with 85k miles on it. The timing belt and water pump has been replaced. What I'm mostly concerned with is the potential sludge problem. The carfax is clean and indicates that the owner even took it to the dealer every 3k miles for service so it looks well maintained.
My question is, is there any way to check for a sludge problem without taking the valve cover off? I don't know if the seller would be too thrilled about this.
Also, what are some indicators of other potential problems I should look out for? When do CV joints usually go out? Shocks? Alternator? Transmission? Thanks for the info guys. Good forum.
Agrippa is offline   Reply With Quote
Old 07-11-2008, 10:03 PM   #2 (permalink)
Do not buy from
View Zviator's Photo Gallery
Yes, u can check the sludge without taking the valve off IF u are superman, lol. Just flush the whole system with seafoam.
For other's concern, a test drive would speak for itself.
How much are u paying anyways?
Zviator is offline   Reply With Quote
Old 07-11-2008, 10:05 PM   #3 (permalink)
Hes asking for 5500.
Old 07-11-2008, 10:10 PM   #4 (permalink)
Do not buy from
Carfax clean is a good start, what options the LE got ? ABS, leather, moonroof ...
Old 07-11-2008, 10:45 PM   #5 (permalink)
just the basic stuff. no leather, no moon roof, no alloy wheels. Just the way I like it.
Old 07-12-2008, 12:26 AM   #6 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
For Sludge, you really need to take the valve cover off.
CV Joints: As long as the boots are not ripped, they are fine. Only time I have seen a CV joint on a Camry go bad is with a ripped boot.
Struts/Shocks: Depends ont he road conditions in your area. My friend has a '99 Camry with 87k miles, and the struts are BEYOND dead, but it spent most of it;s life as a NYC car. On the other hand, I changed the struts on my dad's '96 Camry at 100k miles, and they were not too too bad yet. So all depends on the road conditions in your area.
Alternator: Random. My old '92 camry had the original one when I sold it at 190k miles 3 years ago. The one in my current '96 camry crapped out last month at 120k miles.
Transmission. All about how the previous owner drove it. Normally, the tranny hold up well. Check the tranny fluid though, and see the color. It should still have a redish tint. If it's black, thats not really good. If it;s brown, get a tranny flush.
Other then the sludge issue which you know about, there is nothing else really except the usual basics to check over.
5 Lug Corolla WHAT?
Old 07-12-2008, 12:58 AM   #7 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
have a TRUSTED mechanic check it out..
the IAC unit goes bad here and there- this causes the car to have a hard time starting when the engine gets cold..
there's a service bulletin for the catalytic converter where you'll get sulfur smell through the a/c vents- in the 3500-4300 RPM range .. usually- stopping in front of an up-hill road and accelerating to the top will make this problem show up if its present.
.. good luck!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 07-12-2008, 03:50 PM   #8 (permalink)
Do not buy from
.. good luck!
ADD ON: when u get knocked up, passed out and die then u know its present
Old 07-12-2008, 03:52 PM   #9 (permalink)
Looking at a new owner of a 97 Camry LE. 85k miles. Timing belt, water pump replaced. Great carfax. But all wasnt perfect. The wheels were a bit unbalanced (shaking at 75 mph). And worst of all. The interior was covered with faux wood trim.
