5SFE Engine Build, Turbo Build Delayed. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2008, 11:24 PM   #1 (permalink)
View Ravie_g's Photo Gallery
BAHHH long time. had to delay my turbo build. ran into some personal issues. i have some cash left. not enough for a complete turbo build. BUT i have enough to build the engine. my question is, im planning to build with oversise 87.5mm pistons so will stock components run normally with this? (ecu? injectors?) just wanna make sure.
TIP#134: Always make a note of the current speed limit on the road you are driving on. Just in case you need to slow down.
Ravie_g is offline   Reply With Quote
Old 07-18-2008, 11:18 PM   #2 (permalink)
bump
Old 07-19-2008, 06:32 PM   #3 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
what size over bore are you doing because 87.5 is stock 5sfe piston size?
megamac83 is offline   Reply With Quote
Old 07-19-2008, 06:36 PM   #4 (permalink)
megamac83's Avatar
Yeah they will work only if you get your entire map redone, because since we are speed density driven cars any alteration to our internals will totally throw off how the car responds, so while you might not need to change injectors you will need some type of turning that will take into note your change in a/f, but sides that you should fine, if you are just running an na setup with bigger piston!!!
Old 07-20-2008, 09:46 AM   #5 (permalink)
Ah...i thought it would mess up the ecu. gotta get it tuned. okay thanks, and im just gonna run n/a for now. building it to turbo. so in stead of me putting a stock engine then pulling it out....blah blah... doing bigger forged pistons with performance rings, forged connecting rods, cometic gasket, full seal redo. MIGHT change head to 3sgte to put the turbo in. Should be pretty ballsy when im done
Old 07-25-2008, 10:12 PM   #6 (permalink)
BUMP
Quick question, as said by megamac, i will need tuning. will a Emanage blue be good for doing this after installing the parts?
and the bore for the 5s is 87.1...from what I've learned.
Bore & stroke 3.43 x 3.58 inches, which is 87.122 mm.
Oversize to 87.5
Old 07-27-2008, 06:14 PM   #7 (permalink)
megamac83's Avatar
sorry your right about the bore size, and no you can't put a 3s head on a 5s block, this procedure is very complex for the longest people thought all they had to do was get the head and everything matched up, WRONG!!! While the 3s and the 5s have many things in common, their heads are not interchangeable, due to difference in oil and coolant passages. The serious only way to get a move like this done would be to first have a full 3sgte motor. The next step would be to take the head off and take the pistons and the crank out. After you do it you bore out the cyl. and then drop in the crank and piston set for a 5sfe that is how you get a true 5sgte, its a 3s block bored out to get 5s internals since 5s internals are beefy (crank and connecting rod only) the 5s piston is the 5s's weakiest link!!!!
Old 07-27-2008, 06:16 PM   #8 (permalink)
engineer in training
Gameroom cash: $141655
http://celicatech.com/forums/showthread.php?t=17078
Old 07-27-2008, 06:38 PM   #9 (permalink)
yeah, sticking with the full 5sfe setup, how much HP do you say a 5S rod can withstand? rods are freaking expensive.
Old 08-09-2008, 01:34 AM   #10 (permalink)
megamac83's Avatar
Rods are pretty expensive when you go aftermarket, but, its not really clear how much power they can take!
