Its tricky for sure, and ezly broken...........( I've busted a bunch of em)
Insert a small flat head screwdriver at base of the handle between it and the bezel (the the lower red dot)gently lift up the screwdriver (prying down on the bezel) while pulling out on the bezel with ur finger tips (at the area marked in white)...u'll feel and see the corner come out some!!....now insert the screwdriver at the top red dot, (between the bezel and the lock), and push down on the screwdriver (prying up on the bezel) U should see a metal pin, thats what ur relaseing at the top. The upper corner should pop out alittle like the bottom corner did.
Now pull on the door handle, like ur opening the door, while pulling/sliding, back on the bezel and BAM, it should come off.
Now the good news is, if should u break it, PM me as I have a few bezels for sale!
