Door - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2008, 10:55 AM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Door
The front passenger door will not open from the outside or inside,
Is there a way to open it? kick it OUT? How hard is remove the door panel
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 07-16-2008, 11:56 AM   #2 (permalink)
The Messiah
View scott.joyner24's Photo Gallery
door won't open
where the door handle is at on the inside, there is a plastic molding around it, with a screw holding it in. unscrew it and pull the molding off. you'll see little metal rods going to the handle. are they broke? is the door handle itself broke?
scott.joyner24 is offline   Reply With Quote
Old 07-16-2008, 12:12 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
What year model Camry is it. The 1990s had a recall for this kind of situation. Some electrical component fried and would not allow the door to open. I believe that it affected the locking mechanism. Does the lock button open & shut? If Scott's suggestion doesn't work you may want to check into this.
I would be surprised if you could kick it out.
Without being able to open the door I believe that you will end up having to rip out or cut the door panel to remove it. There are some screws behind the frame when it is closed.
Kep
Old 07-16-2008, 02:37 PM   #4 (permalink)
Mr.Nutcase's Avatar
It is a 1996 Camry
