Gas Hatch Release Broke :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2008, 04:17 PM   #1 (permalink)
View n0rad's Photo Gallery
The other day I went to get gas but my gas hatch wouldnt release. I tried prying it open with a screw driver but no luck. I went into the trunk and used to secondary release to open it. I discovered that the little "nub" that pulls in came come out or is broken. Like I can pull it out. I had a friend pull the release while i watched if it actually went in and out and it does, so the cable is not broken.
Has anyone encountered this before? I tried taking apart the end but I cant figure out how it comes apart.
1997 Toyota Camry LE
JBL GTO 75.4II / 601.1II
JBL Power P650C (Front) MTX TDX6903 (Rear)
2 Cerwin Vega HED-10
n0rad is offline   Reply With Quote
Old 07-16-2008, 04:27 PM   #2 (permalink)
xet
View xet's Photo Gallery
i dont remember perfectly but i had a problem with the gas cap a few years ago, i think it was the spring or something and we just replaced it and its been fine
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 07-16-2008, 04:44 PM   #3 (permalink)
its not the gas cap. its the little nub that releases the hatch.
Old 07-16-2008, 05:19 PM   #4 (permalink)
Moderator
eyeball96's Avatar
Gameroom cash: $797377
iTrader Score: 59 reviews
There's a plastic spring on the gas door, that makes it pop open when u pull the release....I think their pretty cheap at the Stealership..I had one break on the Daughters 99....I made a spring clip out of a stainless steel large paper clip...just needed the spring tension to pop it out!
Worked fine, till she totalled it.
Old 07-17-2008, 02:55 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
On my 95 sedan I can open the trunk, pull the liner away from the side and see the mechanism. I can press up where the cable connects and the door opens. No cable necessary. If the door "spring" is broken (mine has two rubber looking nubs) then you should be able to release the lock while gently pulling out on the door. (I'd use a plastic card rather than a screw driver) Until you get a spring replacement put a piece of foam between the door and the body to push the door out. (A chunck of that weather stripping with sticky on one side works OK.)
Kep
Old 07-17-2008, 03:42 PM   #6 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $263242
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 07-17-2008, 03:43 PM   #7 (permalink)
Old 07-18-2008, 12:13 AM   #8 (permalink)
i dont think i explained it properly. ill get a picture or two up tomorrow.
